Re: 45hp mariner Oiler/Fuel Pump
I doubt the fact your oil pump is bypassed has anything to do with your problem.<br />I have a 1994 40 hp 4 cyl. Merc, I believe the same basic motor as yours & I'm considering bypassing mine before next season as I just dont trust these injection systems especially after a decade.. <br />The oil pump is driven by a gear off the crankshaft & supplys oil to the fuel pump I may be wrong as I believe your motor has the earlier oil injection setup but I cant see how the oil injection being bypassed has anything to do with you not getting full RPM's ..<br />First thing that comes to my mind is gas tank vent clogged open ? Correct prop ? Linkage properly adjusted for full RPM's ?<br />Fuel filter backwards ? Carbs dirty out of adjustment ? Stuff like that..<br />First post for me but long time lurker
