Motor has been run very little over last couple of years. I let it go 4 months thru winter without cranking it. Will not start. Checked spark- OK. Fuel looked a little dark. Pumped fuel out of tank.Dumped water seperator. Took fuel line off tank, pumped fresh fuel from gas can through squeeze bulb, fuel diaphragm pump, water seperator and out the drain on vapor seperator. Checked diaphragm pump- working good.<br />Only getting 2 PSI from discharge of electric pump, should be 35-39 PSI. Took fuel pump out of vapor seperator. I hooked it up to a small 12V power supply, did not run until tapped on it. Appeared to have broke loose and OK. Put everything back together and tested and repaired leaks. Tried to start motor no luck. Fuel pump pulses ( clicks ) about every 2-3 seconds from the instant the key is turned. Voltage to pump pulses also. Fuel pump resistance is .9 ohms as book specifies. Is there anything that could cause a voltage problem to the pump. I want to be certain it is the fuel pump before I spend $675 for a new one. Any thoughts on my problem.<br />Thanks in advance.
