MERCURY 7.5 HP REVERSE LOCKOUT PROBLEM
PICSTEVE
I'VE RECENTLY PURCHASED A 7.5 HP MERC BUT IT DOESN'T LOCK IN REVERSE OR NEUTRAL. IT HAS A BAR RUNNING ACROSS THE BACK THAT THE MECHANISM CAN NOT QUITE REACH (EVEN IF IT COULD IT IS TOO CLOSE TO THE BOAT TO GET BEHIND), AND IT HAS A BUNCH OF HOLES DRILLED PARALLEL TO ONE ANOTHER RUNNING UP THE BRACKET THAT LOOK LIKE A PIN WOULD FIT IN FOR DIFFERENT TRIM ANGLES. AM I MISSING THIS PIN, OR IS SOMETHING ELSE AWRY?<br /><br />P.S. THE REVERSE MECHANISM ALSO NEEDS A LITTLE HELP, WHEN YOU SHIFT IT IN REVERSE IT BARELY MOVES THE ROD.<br />THANK FOR ANY HELP ON THIS, FISHING SEASON IS STARTING SOOOOOOON.<br /><br />REGARDS
Laddies
Banned
Re: MERCURY 7.5 HP REVERSE LOCKOUT PROBLEM
You are missing the tilt pin, what you are looking at is a tie bolt for the clamp brackets
PICSTEVE
THANKS LADDIESSERVICE...I GOT BOTH FIGURED OUT NOW.
