My new to me 95 merc 2 cycle 60 hp 3 cyl starts and fast idles fine, regular idle is very low.  No pee stream.  Water temp approx 38 degrees, air temp 55.  Put in gear it dies until motor warms up 5 min, then you can very slowly urge it to get up and go.  It helps if you push in the key to engage the enrichener.  It then runs fine up at 4500 thru 5500  but try to cruise at 4000 and it fades back to 3330 then accellerates on its own back up to 3700, then fades back, etc.  Holding in the enrichener helps and it will stay at 4000 when the throttle is set to about 4300.  By the way, still no pee stream after running over 20 minutes.  After docking I felt the powerhead and it was about 75 degrees all over.  <br />Thermostat and gasket look fine. Plugs are new.  Compression test cold is 125 all cylinders.    <br /><br />I suspect that the idle circuit in one or more carbs (3) is gummed up.  The idle air screws are quite accessable so I'll try some carb cleaner after removing and something in the gas.  I guess the next step would be tear the carbs down and soak them to remove the gunk, re-gasket and reassemble.  <br /><br />1) Think there's any magic gas additive that can clear this up?<br />2)  Is the no pee stream normal?
