Re: overheating sounder
By running the engin, and the pee hole was working, you may have help cool down the engine with the water pump. Do you have a water pressure gage? This inexpensive gage will help by giving you what you need to know with out looking back at the motor. Also by monitoring the gage you will know when your water pump is getting weak, and will to be changed. It takes a lot of the guess work out for you. <br /> Back to what might of caused the over temp alarm. You said you where in weeds, your motor may have picked up a small amount of the grass into your water pump and in to your water jacket, temperarly blocking the water flow. It doesn't take long to overheat an engine. By the time you noticed the pee hole working it might have pass the weed.
