Re: IL6 Question
Hi Stan,<br /><br />Good to see you back. <br /><br />Define 'crankcase cover'. Are you talking about the cover that the spark plugs are inserted through, or the cover that the carbs bolt on to? <br /><br />If you're talking about the cover on the front of the engine (carbs bolt onto) then 'No', you can't interchange them (theoretically), I have seen it done though.<br /><br />If it's the water cover on the combustions chambers, then you could use a cover from an engine up to 1972, but the part changed after that.<br /><br />Chris.........
