I just bought a used boat with a 2000, 3 cylinder 2 stroke, 75 hp Merc. Outboard. The engine has 26 hours on it, has not been used in the water since 2002, and previous owner started the boat once a year since it's been in heated storage. I drained all the old gas and put in new. I also put in new plugs. THe boat runs very rough at idle and lower speeds (sometimes stalling) , but seems to be better @ higher RPM'S. I checked the plugs after running figuring it was only running on 2 cylinders, and the plugs all looked equally new and slightly wet. Any suggestions would be appreciated !
