1986 115 carbs
rjfshadow
hello,got a question about correct jet sizes for my 3 carbs?i have a solec manual and it only lists 1 size for all three carbs.and the mercury parts express lists jets for 2 of the three carbs and their different sizes.where can i find the proper jets for these carbs?main and vent.thanks for any help.rjf
Clams Canino
Re: 1986 115 carbs
If it's a stock '86 115 in normal use you can use .074's in all 3. The Merc dealer will have them.<br /><br />If you plan to run WOT all the time (not reccomended) you outta use .076's in all three. <br /><br />The vent jet at the top of the float bowl can be left alone, but you should insert a BB into each of the 3 black tubes leading to the bowl covers to disable the "economizer" circuit.<br /><br />-W
