Mercury 30 (No power at Full Throttle)
jc29906
I have a mercury 30hp (1999) It will start n idle perfect but will not pick up enough speed when the throttle is buried, It used to plane just fine. (I cleaned the curburator and replaced the plugs) any help in this matter will be greatly apreciated! thanks :confused:
Vlad D Impeller
Re: Mercury 30 (No power at Full Throttle)
it could be fuel related, check the fuel lines, primer bulb, fuel pump, and the vent on fuel tank :)
PETER JAMES
I have the same problem see my post<br /> 20hp mariner no high revs ???
jc29906
Problem solved, took it to 2 repair shops but ended up figureing it out at home. Linkage in the control was messed up where there was alot of play, (carb was only opening at 1/4 of the way. Now it flys! Thanks!
