Charlie Britton
- Jul 13, 2005
- 3
I have a 1995 Merc 150 with carbs. After starting the motor, and as long as it<br />is in idle, the motor runs fine. I have to "jog" the throttle 2 or 3 times to get the<br />motor to run above idle, but then the motor runs fine at slow speed or high speed. If you push the trottle up slowly it sounds as if it backfires and the motor cuts off. Any thoughts?
