We're novices but have taken apart lower unit and have checked the water pump and impeller for damage. Everything looks good. Blew air through pee-hole and passage is fine. No water is coming out of pee-hole, water stopped coming out while engine was running. We cut the engine right away but still haven't found the problem. Any ideas on anything else it might be? Mercury 175hp oil-injected outboard. Need expert advice asap--gotta get rid of the tan lines
