mercury 175xr2 sport jet
kempkerm
I just purchased a 2001 Tracker Pro Jet w/ the 175xr2 sport jet. s/n of motor is OE385863. The whole unit only had 43 hours. The motor now has 46 hours on it and the oil pump went out. So I am stuck with a hefty repair bill. It appears to have had a plastic gear that drives the pump and it broke. There is no alarm on the oil pump itself. Does any one know if there was a defect with this particular motor or recall? Fishing for help.
WillyBWright
Re: mercury 175xr2 sport jet
Nope. What happened was that the oil pump driven gear rusted and wore the drive gear out. That happens with V-6 mercs that don't get used much. Nothing worse for an outboard than sitting around. :(
Dhadley
If the motor is still OK and all you need is the oil injection there is a mechanical replacement for the gear set up. Saves you from tearing down the motor to replace the gear. If the motor is hurt then it has to come apart anyway.
kempkerm
thanks fellas. i just got it back three days ago. i had all six cylinders bored to keep it balanced. it cost over $3000 total for the rebuild.
usla1
Originally posted by kempkerm:<br /> thanks fellas. i just got it back three days ago. i had all six cylinders bored to keep it balanced. it cost over $3000 total for the rebuild.
Who makes the auxilliary oil injection pump that you are speaking on Mr Hadley?
