Re: 1988 Mariner 50 HP 2-stroke oil injected
I am aware of the spray stuff you speak of and...it doesn't even scratch the surface. The most tiny bit of gum can give you a can of worms. A full disassembly is necessary, that is if you have spark on all cylinders. <br /><br />Removing the carbs is easy, I could give a walk through if you like and then a walk through the clean and reassembling. A digital camera is useful when disassembling so you can see how it looked befor you took it off. Even better, a picture will show me what type of carbs you have. Check to see if you have the carbs that fit this description.<br /><br />-With the front cowling cover and air intake box off.<br />-You see the throttle sutters inside the carb throats(which you said open all the way when you go to full throttle).<br />- There should be to plugs on either side, same level as the carb throats, those are the idle jet plugs.<br />-There should be a bowl under that, attached to the upper part of the carb with 6 retaining screws. On either side of the bowl should by two plugs (the main jet plugs)<br />-And finally to complete the description, on the top of the carbs should be a metal plate.<br /><br />If you have these carbs, they are the same ones I have I can help you clean them. If not you will need to get a Seloc or merc factory manual on your engine (Which you should get anyways, they pay for themselves).
