Re: 1975 500E - Water in bottom two cylinders
R, the seals shouldn't leak even if they are a bit far into the housing; as long as the surface of the crank is OK where they are contacting, should be OK.<br /><br />I guess it's possible the exhaust adapter plate could be spraying water up into the exhaust passages; when you have the adapter plate out, also check the water tube for pinholes/cracks. Check the water tube's rubber sealing grommet and replace if it looks bad.<br /><br />You can use some sealer on the gaskets but if you end up with the new blue-color gaskets, they are made of 'sandwiched' material and don't really need anything on them. Won't hurt if you do, though.<br /><br />On the crank seals, usually you can drive the first one all the way down until it stops in the bottom of the machined cavity. Then drive the upper seal down below the plane of the ball bearing, but not hitting the lower seal. Make sure of course that the lips on both seals point downwards or it'll suck water in. <br /><br />You'll probably also notice some small holes in the bearing cap, going from the I.D. to the O.D. These are the bleed holes to recirculate excess fuel/oil to the upper end of the motor. Be sure you don't block these holes with either seal.<br /><br />Your bearing cap will either have a check valve embedded in the cap, or will have a check valve screwed into the lower part of the block. Make sure the 'check' function of this valve works properly by blowing from both directions; it should only blow freely one way. If the check valve isn't working you should replace it.<br /><br />G'luck............ed
