1970 9.9 no power wot
roachsregal
i have a 1970 merc.9.9 with no power thru the throttle range -turning the carb mixture screw does not change the performance unless screwed in all the way to make it stall-idle seemes fine -starts fine -but no power--any suggestions??-carb was rebuilt -thanks for any help<br />scott
Laddies
Banned
Re: 1970 9.9 no power wot
It must be a 9.8 and sounds like it's running on 1 cyl
joblo33
Do a spark check on both cylinders and tell us what you find.<br />Eric
roachsregal
Originally posted by roachsregal:<br /> i have a 1970 merc.9.9 with no power thru the throttle range -turning the carb mixture screw does not change the performance unless screwed in all the way to make it stall-idle seemes fine -starts fine -but no power--any suggestions??-carb was rebuilt -thanks for any help have spark to both cylinders <br />scott
roachsregal
i have spark at both cylinders -not sure if its a strong enough spark -should i pull flywheel and replace points ect . or could this be the reeds not working properly?
dajohnson53
For what it's worth, I had a similar problem with my '74 9.8 (merc 110). The plugs would spark, but when I used an actual adjustable spark tester, I found one spark was weak pointing to a weak coil. When I replaced it, it ran much better. Do a search for "spark tester" to find pointers to commercially available ones and easy home made ones. (I bought mine from the snap on guy for $10 or so). Check with your local dealer or www.oldmercs.com for the exact coil for your engine, if you find it is defective.
dajohnson53
Another thing if you suspect the coils aren't up to snuff: When the thing is running (in the lake or a barrel), remove one spark plug wire and see if the idle changes. <br /><br />A -If it quits, it probably means there is one plug firing and you removed the good plug wire. <br /><br />B -If it doesn't change it probably means that you have one plug firing and you disconnected the bad one.<br /><br />C - If it changes audibly it probably means you have two plugs firing and by removing one you've cut it back to one.<br /><br />You then reconnect the plug wire and repeat A, B and C with the other plug wire to see if the results are consistent with what you'd expect.<br /><br />If A and B are your situation, you can remove and switch the coils (easy to do) and see if the problem follows the coil. You can also switch the plug wires to see if the problem follows th wires. While you're doing all this, you can examine the coils and wires leading to and from them to make sure nothing looks obviously bad and that connections, grounds, etc. are good.<br /><br />But I'd do both these tests and the spark tester see what you think.<br /><br />By the way, when you remove the plug wires, use an insulated pliers and I also recommend you wear insulated leather or rubber gloves. You might get a good jolt otherwise!
Fastjeff
That motor--which is a 9.8, by the way--has a fixed high speed jet. Suggest you pull the brass plug at the bottom front of the carb and see if there's any crud in there. That would lean the motor out and burn a piston if it keeps up.<br /><br />Fastjeff
