Hey all,<br /><br />I have a 1991 90HP Mercury that I Cannot get to idle. I have to start it with the throttle half open viewing the fact that this is THE ONLY way it will start. As soon as it starts (usually takes various attempts) I warm it up at 1500 RPMs. After a minute or so I try to easy throttle to check if it idles but it ALWAYS stalls. Yesterday I was checking the plugs for spark when I grounded the number two plug; it fired right up!! And had a smooth idle, Ive read in other posts that the 3 cylinder loopers idles better on two cylinder instead of all three but this lead me to believe the plugs are not firing in the correct order.<br /><br />Previous to this (when I started the engine at high idle) it always had this strange sound from the carbs like someone is doing a gargle
. But yesterday when running on cylinder 1 and 3 this disappeared. <br /><br />Ive done all the basic maintenance: rebuilt carbs, checked the reeds, lines, filters, fuel pump, new plugs, cleaned wires, decarb. I also checked the electrical components; all tested out ok. I have the red stator kit. Timing is also ok at 4 BTDC<br /><br />I have the Clymer manual; the swithbox is wired to the coils as follows: <br />Top-cylinder 3<br />Middle-cylinder 2<br />Bottom- cylinder 1<br />The rest is color coded so no problems there. <br /><br />Any help is greatly appreciated and sorry for this long story its just that Ive tried EVERYTHING with NO results.
