Was running my '85 mercury 90hp inline 6 OB today, running at around 25 MPH when I felt a thud. I threw it in neutral and trimmed up the motor to look at the prop, looks fine but the boat ONLY engages in reverse gear now, forward it just revs but no forward propulsion. Had to ride it in 2 mi in reverse to get back to launch. Got home and check cables, prop cant figure it out, prop spins in forward and reverse when on a hose. Removed the prop and verified the shaft is spinning in both forward and reverse. So I am down to faulty shift cable, spun hub, or busted lower unit forward gear. From my symptoms do you have any ideas or can you tell me of those 3 can I eliminate any since it DOES go in reverse and bite the water just fine? Thanks
