merc/mariner possesed trim/tilt
lucky1lucky69
Any help on this problem will be much appreciated.....the engine is a 60hp Mariner serial no.9502702 3cyl with PTT the PTT part being the problem ..it will trim up fine and down fine until it comes into contact with the 2 damper pistons this is where the PTT motor starts to struggle ..if pressure is applied to the engine it will fully trim down but not without a fight and has on occasion started to lift of its own accord whilst trying to trim it down.....I have checked the oil level..fine ...left the filler cap off for a couple of hours to allow trapped air to escape..none present...tried draining some fluid out ..wont trim properly( was getting desperate by this time and running out of ideas)...If the bleed nut is removed the 2 dampers rams an be fully retracted thses have no pitting or leakage.and finally nothing is physically binding!!! It almost seems like the pressure within the unit can not escape when the leg is trimmed down Is this a viabile option? and if so what is the answer? .......one final thing it will freely trim down if the large override nut is loosened.Again ANY help would be great. Thanks in advance Marco :)
alana
Re: merc/mariner possesed trim/tilt
i reckon one of the seals is leaking inside.even though ill try to fix most things on my motor, hydrulics i leave to the professionals, as they will or should have all the special tools and replacement parts
lucky1lucky69
Would a leaking seal stop it trimming down ? It really seems more like a blockage. Has anyone had this problem before or a PTT unit for sale?
alana
if oil gets past a seal it can fill a space that should empty so stoping the rams going down
