Hello everyone<br />I hope some one can help. I have no tell tale stream of water from the engine. Its a 1984 60hp 3 cyl. The impellor is not very old, ive had it apart so many times now trying to fix it. I put a drill on the end of the main shaft and i get a powerful stream of water from the end of the long brass tube, but when i put it all together i get nothing from the little outlet. Ive removed the hose from the engine and all is clear. all i get is some steam from the tell tale outlet. I also am getting some water coming from the two outlets of the exhaust on the back of the engine and a little from around the two bolts and mountings that hold the steering arm to the block. Should i renew the impellor even though it seems to work? Should there be water exiting from the exhaust holes?<br />Many thanks in advance.
