This weekend, while out fishing, I encountered total power loss on my 70 hp yamaha. Ran the boat for about an hour without any problems. Stopped to read maps. When I tried to start back up, hard to start (kept dying), once I finally got it started and advanced power, boat powered up as bow was starting to plane out, lost pretty much all power. Was able to make it back to the landing running at full throtle with a speed @ 1.5-2 mph's. Once back at the landing,<br />1)Pulled plugs - a little wet but not bad<br />2)Checked fuel filter/bowl - no water or trash<br />3)Checked all fuel lines and carb mountings - no defects noted.<br />4)Drained fuel bowls - no water<br />After letting engine sit for a while, could go out and power up again, same thing, start to plane out and engine rpm would drop and no power. If you brought it back to idle it would die. When you restart, wouldn't develope any power at all. Shut it off for 30-45 minutes then try again, just a momentary burst of power. After scrubbing a good day of fishing and got boat to the house, did a compression test. All cly's running @125 psi. Anyone got any ideas?
