All of a sudden yesterday my motor took forever to start<br />It now will not start without lifting the lever (Remote 703)(Choke I assume)but as soon as I put the lever back down it cuts out unless I am lucky enough to quickly get into gear and go<br />It's as if the idle is too low but nothing has been done to change anything<br />When I got home I took off the cover and found fuel in the bottom of the pan<br />I checked all fuel lines and pumps but could not see any leaks<br />Before this happened it was going fine except it would not exceed 4000 rpm's which I knew was not correct but as it was running ok I decided to leave that problem until next annual service<br />I recently changed all the plugs and it was going ok<br />I have posted previously about the low rpm's but this problem is new <br />The motor is a Yamaha V6 Oil Injected 150hp 1987<br />Any help is always appreciated<br />
