ConroeCrappieSlayer
- Nov 21, 2003
- 1
We have a 1983 Suzuki DT140 with four cylinders. We took it out on the water Saturday and it idled just fine, but only when we sprayed starting fluid in the carbs. But when we shifted it into gear, it would go only between 10-15 miles per hour while holding down the front lever down that was connected to the carbs. But when we idled, it would revv up to high rpms. Also, some of the Carbs on it were very cold, and a couple were warm. We added oil to the gas and the oil reservoir to see if the oil pump was working, because the motor was sitting up for a couple of years. Do you think that the oil just fouled up the plugs? Or what? Any suggestions?
