Re: yamaha 90 misfiring
If you haven't already, go to the bottom of this web page and buy a manual, best $30 dollars you will ever spend on your boat. The manual knows all. Usually a kit is available for rebuilding carbs. If so it would probably include all or part of the float valve assembly, and new gaskets or O-rings that should be replaced. Outboard carbs are pretty simple and it is a job easily done. Removing them is probably more difficult than rebuilding one. Remove them, disassemble them, clean the carb, with emphasis on the orifices inside, with carb solvent and compressed air (you can buy a can of air at Radio Shack if you don't have compressed air) and install the rebuild kit parts. The important thing is that its not a beauty contest for the outside, it is the inside of the carb that counts. Spraying carb cleaner in the carb throat while its still on the engine doesn't count.
