Re: yamaha 225 OX66 dies at high speed
First of all I want to mention how handy this site is for troubleshooting, it is awesome, I had this same problem with an 2003 200 V-max, it would run at idle and plane fine then after a 3/4 mile or so it would die and if you would pull the throttle back it wouldn't stall completely, once it sat for a few minutes you could plabne again witht he same end result it would stall, previous to this issue I was having real similar issues and changed the water/fuel seperator, dumped the clear plastic fuel bowl on engine, changed the plugs, water pump etc, finally I started questioning how the clear fuel bowl on engine seated and realized it was leaking a small amount of gas down the outside, I didnt have it seated properly and the fuel system when requesting large amounts of fuel at WOT would starve ...causing it to stall..going to run it again this afternoon although I am real sure this was the issue,.......original issue was moisture in the VSP tank, then an improperly seated fuel bowl was result and second issue after draining VSP....Seafoam here I come
