Rhondalikesme
- Feb 3, 2005
- 4
My 2000 Yamaha 225 VMax: Main oil reservoir above gas tank does not appear to be pumping oil into the tank on the motor. Last fishing trip, cruising along just fine and buzzer goes off, limiting rpm's to 2000. Thought maybe grass on motor, temperature sensor, but no. Trace it to low oil level in the tank reservoir on the motor. There was plenty of oil in the main oil tank. I had to remove the cap on the tank (motor) reservoir, add oil, then motor ran fine. Is this a common problem? Is the problem the pump on the main oil reservoir? Can this be easily replaced? It is very easy to access. Thank you for your help.<br />Richard B
