Re: Follow up questions on: Yamaha 225 assembly questions
Robolt,<br />Thanks for the information I really do appreciate it, I'll pick some up. Hope you dont mind some additional questions, I wand to be sure I do this right the first time.. <br /><br />(1)I was cleaning the heads up last night and noticed (on one of them) on the very bottom, in between two bottom bolts where the water journal that flow around the top of the head and the cavity is corroded to the point its not as thick and not as true of a surface as the rest of the head. The corrosion is actually not on the water journal side but the side of the cavity between the two head bolts. A friend was over while I was working on this and he suggested marine tex to build it back up if I wanted to, as it looked to be on a side that is just an empty void. ??? <br />(2)I removed the inner exhaust cover so that I could inspect the rings, etc.. All looks good, pistons, cylinder walls and rings. I do have some minor corrosion on the inner exhaust cover along with carbon build up. The corrosion was on the same side that I thought was breached.. (Although I never lost compression, it was the gaskets that looked suspicious to me.) Should I just clean it up and put it back in, or do I replace it?<br /><br />Thanks in advance!<br /><br />Fred
