I have a 95' DT75. At idle all seems to run OK, head seems normal to the touch, after the hole shot 3-4 seconds on plane I start getting surges and at WOT it is bogging down. I have inspected the fuel system from cleaning the tank, pick up tube, replacing primer bulb, had the fuel pump apart, rebuilt all carbs,(which looked very clean to me)I have a water seperater . Tried pumping the bulb when running on the water and that didnt help. Ran a timing light while under power, it was reading around 24 deg BTDC (hard to tell by my self). Does this motor have an over heating circuit that acks as a governer to save the motor?
