Re: yamaha 2000 f115 4 stroke dies at high rpm
the filter that is internal in the engine that is prior to entering the fuel injectors could be clogged. I had this problem with a 4 stroke 200 hp engine. This filter is the size of a nickel and very expensive to replace. over $1000. Shell gas payed for the repair for me because i was able to prove that this was the only gas i used. warrantee will not cover this problem because of contaminated fuel.
