Re: yamaha outboard
Hi,<br />So a Yamaha 50 hp 2-stroke about 1997 or so is what You have.<br /><br />The tachometer:<br />So you only get 2800 RPM (revolutions per minute) today?<br />But it was 4600 RPM before it seems.<br /><br />Your outboard should probably at full throttle have about 5500 RPM. So You are little low on RPM if 4600 was your max RPM at WOT (wide open throttle) before. But that is another problem (probably solved with a prop with 2-3 inch lower pitch).<br /><br />Personally I would first make sure I had sparks on all spark plugs.<br />Then make sure it runs on all cylinders (it has 3).<br />Then I would make sure I had proper fuel delivery (from tank trough bulb and lines trough fuel filter and last to the fuelpump and trough the carburators.<br /><br />Any alarms going on? Overheat alarm?<br />Not sure at what RPM the rev limiter kicks in but it would probably be something between 2000-3000 RPM.<br /><br />When was this outboard last serviced?<br />Has the impeller (rubber water pump wheel) been changed in last 2-3 years?
