1990 yamaha 225 low oil alarm
The LCD oil indcator alarm intermitantly goes off when in gear. When i take it out of gear it stops, then when i run it slowly it is ok until i accelerate then it goes on again. The oil reservoir is full, and it appears to be emptying on a regular basis. Runs rough immediately after alarm goes off, but if i let it lay for an hour or run it at low rpms it is<br /> fine.
rodbolt
Re: 1990 yamaha 225 low oil alarm
check the oil filter in the remote tank.
I TOOK YOUR ADVICE ON CHECKING THE OIL FILTER, BUT I WAS UNABLE TO FIND ANY TYPE OF FILTER BETWEEN THE EXTERNAL OIL TANK AND THE MOTOR. ANY OTHER SUGGESTIONS?
Originally posted by JOEY DEAN STREET:<br />[I took your advice and checked for an oil filter for the external tank, but i was unable to identify any filter between the external tank and the motor. If any one has any other suggestions i would appreciate it.
sorry about the caps in the first reply.I am new to this and haven't got the etiquette down yet. I hope that I didn't offend anyone.
