Re: rodbolt- stator
some of my spark plug caps were testing out of range. i replaced the caps. i did clean the sensor. as far as fuel goes. i started at the tank. one tank 2 lines. 2 new fuel water sep. all new fuel lines a year ago. swapped fuel lines at the engines no change. fuel up to the eng is good. the line going into the eng. up to the in line filter and to the fuel pumps vacume checked good. put new o ring on in line filter checked again still good. then 2 new fuel pumps. after cleaning carbs and trying, i swapped carbs still same problem. i cant imagine it being fuel. the carbs that were overhauled worked great on the other eng. I did notice after using the boat for 15 min the problem happened at around 3500 rpm. it started sputtering (missing). then clear up. all plugs look normal color. when my rpm drops off it will not recover unless i throttle back and as soon as i throttle up it drops off at the same rpm. when i pulled the caps off the spark plugs one at a time, i did notice that the spark on some cylinders was stronger than others, so thats when i swapped the plug coils, no change and then cdi, no change. thats the reason why i want to look under the flywheel. thanks rodbolt for all your help...nick
