I horse traded (wasn't a horse actually it was a trailer) for a 1994 15hp short shaft ele start, yamaha motor that the drive shaft was broken, and the prop shaft was bent, it was not run after the person hit a rock and broke the shaft because it would not turn the prop, the question is, how do I determine the proper shims to use when installing a new prop shaft? and is there anything else I should check and see about tolerances while I have it apart aside from the impeller which I will be replacing, thanks
