CWM1250057
- Feb 27, 2005
- 14
Okay, here's the problem. The motor will start fine, but then when I put it in gear it will either stall or won't go above 3000 rpm at wide open throttle. The carbs are CLEAN with new jets, I tried hooking a portable gas tank with fresh gas to it, checked the compression (120 on 1, 2, and 3 and 142 on 4), none of which worked. <br />I can't think of anything else, what could be my problem???<br />Any help would GREATLY be appreciated.<br />thanks,<br />Charlie
