(2003 yamaha 150hp efi vmax vx150)Problem...Only 0-2 psi on (New) water pressure gauge at idle,visual water stream is present on rear of motor,17-20psi at 4000-5500rpm.No overheating Yet!Rebuilt water pump to include plate,gasket,o/rings,impeller....Twice! Same problem....idle is 600/700 rpm.Motor well maintained flushed regularly.Thought I had 5-6psi water press. when brand new at idle???? Thanks for any help!
