Re: 1987 dt175 permissive question
Well..... about the best I can answer that is by spark plug examination. but now that you mention it I'm not sure. It seems that 3 cylinders were firing after examining new plugs, after a short run on muffs. It was obvious that only 3 were firing , the other 3 were just wet. I set the motor aside last year after becoming frustrated and am now determined to either fix or bring to the shop.I have done compression test ( all even) , rebuilt carbs, tested pulse coil, and associated. I'm not sure of my cdi results and plan to test again tomorrrow. The ignition coils were tested by my local dealer and all tested fine.<br />Rodbolt if I had confidence in my local dealer I would have brought it in a long time ago butI don't due to previous visits. The problem here is only 2 dealers within 100 miles. Anyway I degress; Your assumption is right I don't know for sure its randomly firing.
