Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I have a 1999 Yamaha 200 OX66. It runds fine until I get on a plane. I replaced the water pump kit thinking it may not be pushing water to the top of the engine but the problem continues. Any suggestions?
Do you have a good flow from your tell-tale? Thermostats changed? Pressure relief valve not obstructed? Is this a new problem? Anything new hangin off the back of your boat, like a transducer?
It is definitely the temp light that comes on. I have replaced the water pump kit, the thermostats, and this is a new problem. Where is the presure relief valve.....I have removed the head covers for cleaning today.
if the t-stats and water pump are good, and the presure valve is clean then next step is head and watercover removal.<br /> the pressure control valve is low on the stbd side of the ex cover.
