Hey there-searched through the stickies and only found the SX bellows replacement so I started a new thread. I have a 2005 DP-SM 1.78 (M22) with SN 3868912 or 4202142350 drive and a water leak. Originally I thought it was the steering pivot seal leaking and replaced it and still have water. After hanging upside down in the bilge on the water yesterday, I saw that I have water dripping off of the driveshaft and onto the exhaust y-pipe and into the bilge. I'd like to assume it's the drive bellows at this point. First, is there another spot where the water could be leaking? It's not around the inner transom assembly and it's not the pivot seal for the steering. I know the raw water enters there as well and I just can't get to a vantage point to confirm where the water is coming in.
Assuming bellows, which do I need and is there a How To Replace anywhere? In advance...Don S, you are the man! Almost forgot--what parts and part numbers do I need in order to button this up?
