i_build
- Apr 24, 2005
- 144
Hello all, I purchased a 2004 GS-249 and have been getting her in top shape since September. I actually own an 1966 Anna Capri as well but it is as plain as it can be... but a great boat. The issue I have is that I can't find more than marketing fluff when it comes to any documentation online. I purchased the Seloc manual for the engine and drive... but there are things that I just dont understand as far as the dash switches as well as the circuit breakers in the cabin and how they should work. Does anyone know of where I can get a hold of some documentation that provides more detail. I removed the fuse box cover and there is no diagram in it either... so I would like to know what fuse supports what along with the amperage. There are also some multi switches on the dash that have faded text. I never had anything with a holding tank and macerator so I am not sure how that works. Not sure on the water to fill the head I assume it comes from a through hull fitting at the front of the engine in the engine bay. I see the macerator breaker switch but I flip it and nothing happens and I dont know if there is something in there from the prior owner. There's a light in the head that says it indicates when the holding tank is full... I don't know if when the holding tank is full then the macerator will kick on when I flip the breaker? I just went ahead and checked all the fuses in the fuse panel to make sure all were good but I would like to label them as well as know how everything works. I had to bypass the water heater cause it was leaking badly internally but I never had a water heater either. Bunch of questions... but long and short... is there some documentation for a GS-249 that would give me those answers? Please let me know. Thank you in advance.
