dingbat
- Nov 20, 2001
- 16,345
You are correct.......I believe you have that slightly backwards. Red (typically a switched wire) or black are hot and should go to the line or hot terminal, typically a brass or gold screw, White would go to the neutral or silver terminal on 120V receptacles.
Need to stop multi-tasking when answering posts...lol
