Chain worth it?
Nheels
Good day, all,
Currently running a 10kg Delta anchor with 10ft if 1/4 chain and 150ft of nylon rope. I have a 35 cabin cruiser that weighs about 12k.
I am wanting to run all chain, but my windlass will only run a max of 1/4 chain. Think it's worth buying the chain, even though it is only 1/4 inch? I believe the recommended chain size is 5/16th.
Think the chain upgrade will be worth it? My goal is an added layer of security, but I don't want to end up replacing my windlass.
dingbat
Good day, all,
What happens when you hang the anchor?
Do you carry a hack saw or cutting torch to cut the chain?
Sounds risky to me
the chain is for weight (not strength)
the line in the rode is for strength.
going to all chain will be less strong than what you have, and a whole lot more expensive.
5/16" stainless chain has a max working strength of 2400#, with a breaking strength of #9600 when new. 1/4" is significantly less.
1/2" anchor line has a working strength of about 8300#
Nheels
Using line will also absorb more wave action vs chain as it stretches a bit before maxing out. It's less stressful on the deck hardware and not so jarring to passengers while onboard .
Thought about that, but I could do a bridal.
Nheels
Yeah, I was thinking more for anchor security with the extra chain weight. An alternative could be just a bigger anchor as well .
arks
Our 34 footer weighs 12K and I was in a similar situation. The windlass only takes 5/8” double braid, so instead of replacing it I simply got a bigger anchor. The old 22# Delta was sized correctly for the boat but I was uncomfortable after an overnight where a stiff breeze was blowing into the cove where I was anchored. Since I liked the Delta (it never let me down) I got a 35# model. I had to slightly modify the pulpit to make it work, but I feel way more confident now because the new anchor is rated for vessels up to 45’. As far as chain- if the windlass accepted it I would use some, but I’ve found it is not needed as long as you deploy adequate scope. See pic below:
bajaman123
I would resist having all chain...for the reasons already mentioned. In an emergency situation where you need to cut the anchor loose, having all-chain would give me the willies!
Nheels
I like this line of thinking. For the price of the new chain, I could probably get a 35LB Delta as well. Thanks for the insight.
Pmt133
Master Chief Petty Officer
My 33 has ~150 feet of chain in the bow on top of ~500 feet of rode. I always joke it was rigged that way to help keep the bow down. In the bay it's totally unnecessary and I keep meaning to shorten it. The clunk when anchored is quite annoying. Works great offshore.
Nheels
What size of chain and anchor do you run?
alldodge
All Formula cruisers come from the factory with all chain
Had a 27PC and loved the way it held. Hung up twice in all the many years I had it. Had to drop the chain and come back with scuba gear
Pmt133
Whatever it was rigged with. I believe 5/16 chain. The anchor I don't remember the weight but it is a traditional danforth. Next time I'm down I can check the weight.
Horigan
If I were you I would get a bigger anchor and add more chain to your rode, like 50'. On our 10K lb Commander 30 we run 200' of 1/4 chain and another 150' of 1/2" rode, primarily for deep anchorages in BC and southern Alaska. We like the damping that all chain (effectively) provides.
Your windlass may be able to handle a different gypsy that can take 5/16" chain. Just make sure it has the load capacity to lift at least three times your complete anchor rode weight.
Are you out of Tobermory ?----We were at anchor with 33' sailboat off Hope Island.----Vicious squall came through.---Our anchor dragged for a while.----Out of 25 boats only 1 powerboat went ashore.----Video of this event does look scary.----So yes , a hefty anchor and chain are hard to buy when you need them.
