c_douce
- Feb 20, 2010
- 89
Hi, Purchased the old trim, the cylinder attached to the motor trims up, the opposite cylinder has no pressure, just slides, opened the, I would guess the refill valve that has a wire attached, no fluid inside, possible leaked out, if I refill, would It hold and due to that side not working, why does the opposite cylinder still trimming. Is there a detailed video how to dissemble and how to clean out the aluminum pressure hoses. I noticed a couple of boaters posted, but they never received an up-date on their last question. both cylinders are the same. hopefully someone on here has the experience to give me the info or details.
