Hey guys - Two part question..
#1 - I recently acquired a 2002 Bayline with a 3.0 Merc that hasn't ran in 2 years. It does have a crack on the port side of the block (unknown if overheated or not winterized). I Drained the oil out of it and did get some water but it was not milky looking. Put 5 Qts of oil into the fill and nothing shows on the dip stick and there are not visible external leaks anywhere (I have not attempted to run it) I'm at a loss.... any suggestions?
#2 - I'm looking at just swapping the motor out with a known running one. Will a 1997 Merc 3.0 be a direct drop in fit? Only difference I can see in my motor and the new motor is where the shift cables mount up (starboard side vs on top of the rocker cover)
Any input is appreciated!
