bluefightingcat
- May 10, 2021
- 5
I have a Johnson 1998 40hp BJ40TLECR.
I just changed the impeller and I tried to test it out. I added the "water muffs" and turned on the engine. No telltale water. I read somewhere that the normal garderhose does not produce enough pressure to get water out of the telltale? Is this the case? Or is it likely blocked?
