if you want to use a sealant, use permatex #3 non-hardening. it can be cleaned off with mineral spirits
Note: On the Permatex website it says:
I don’t like how the u joint bellows only had a compression seal and no band clamp. That seems like a weak design but maybe not. If you’re getting water in there sometimes it will leak past the gimbal bearing and leak into the bilge. I’ve seen this on both of the boats I’ve owned. But the best way to know is pull the drive and check for cracks in the bellows with a flash light. It’s the only way to check your u Joints and gimbal bearing anyway.Is there a way to tell if the U-Joint Bellows is leaking? That would be very good to know because a leaking bellows can lead to having to replace the U-Joints and the Gymbal bearing and possible worse.
There is a plug on the starboard side to check if water is getting into the cavity where the shift lever and the shift cable guide move back and forth.
Is there a way to check for a leak at the bellows? It seals on the forward edge with a hose clamp and at the aft edge just by pressing against the bearing carrier on the OD. To me, that seems like it would not be that reliable.
I'd sure like to be able to check that I got a good seal.
Any suggestions?
