Attempting to find the wiring diagram for this? I have looked around and can't find the plug that would is supposed to go in there. Any assistance to point me in the direction of it would be greatly appreciated as I'm running into the issue below.
I am getting a single beep alarm at idle and under load at approximately 3000 rpms. At first when the boat was started I was getting multiple single alarm's in a row. Then, under load at 3000 rpms it beeps once multiple times in a row. I then met up with a friend in the middle of the lake and sat there with the boat running for close to 25 minutes in neutral and didn't get a single alarm. When I left and opened it up to 3000 rpms, I would get the single beep multiple times in a row again. I am baffled.
Would the plug missing cause this? I've had a mechanic check it out and everything checks out mechanically and I have vessel view attached and not getting any error code for oil sensor, water pressure sensor, or temperature.
