WellcraftSportsman23
- Jun 24, 2009
- 27
So I have a 2000 MerCruiser 5.0 EFI set up. I live in New Jersey and winterized it properly and started it up about a month ago and about a week ago. Everything was fine oil pressure was good water temperature was good no issues no knocking nothing. Yesterday I went to start it and I got a click. Battery is fully charged, so I figured it might be the starter solenoid. I jumped the solenoid and still heard the click coming from the starter. Decided to pull all the plugs. No water or anything in any of the cylinders however, one of the spark plugs was totally smashed flat. With the spark plugs out, I tried manually turning the engine with no movement. I turned the key to use the starter, and I still got the same clicking which is more of a bang and no movement again. The boat has oil and there is no water in it. My question is, could it be a bad starter? That’s not allowing the flywheel to spin? I also was messing around with the throttle cables however the propeller moves freely, which makes me believe it’s in neutral and the fact that it’s trying to start also leads me to the same conclusion. My biggest concern is that somehow it seized, but I don’t understand why because it ran the last couple days. With that spark plug being smashed, I’m wondering if it’s something that’s been like that all last year and I just never noticed. The engine never ran rough. Any help would be appreciated.
