I just recently in the last year have gotten my project boat ( 1995 cobia 20' with a 1990 Johnson 125 ) close to finished ( if they ever are ) and I was running it at full throttle and trimming it up to see what the top speed would get to and it hit 35 mph and then my overheat alarm went off , so I looked back and noticed the pee stream had quit , so I immediately shut it down.
Used my trolling motor to get up to a dock that was close by and pulled the cowling and everything appeared to be in order , so I cranked it up and it started peeing after about 5-6 seconds and the alarm went off after about 10 more seconds.
While I was trimming the motor up the bow never rose up and it never porpoised up and down , I am hoping I just accidentally trimmed it up too much and the intake screen came out of the water to quit pulling the water in ? But the prop never cavitated and it never porpoised , which is weird . I also have one more question , this is a brand new impeller ( installed it roughly 3 weeks ago ) , did I just ruin it ?
Could anything else cause this problem ? There are only two things that ALWAYS worry me about doing the water pumps on these motors and those are the little plastic drive key that turns the impeller and the little rubber grommet for that water tube that slides into the water pump housing when you put the lower unit back on , could either of these have an issue ?
I am wanting to eventually get a water pressure gauge and install it because I think I could keep an eye on it when I'm trimming it up and know when to stop , or is it as simple as watching the pee stream ?
