Tachometers not working correctly
woodguy81
I have many small issues to sort out on my project here and my latest is non functional tachometers. I have a pair of 6.2 mpi mercruisers. one is a 2002 and one is a 2004. at least that is what the computers are now. These were built from a couple 5.0 mpis that I swapped the parts onto new 6.2 long blocks and got computers for. Back to the issue. The tachometers are way off. reading way high and inconsistantly. Where do I even start to figure this out? I did not look at the gauge setting yet as Im told they can be adjustable for 4, 6 , or 8 cylinders but this is a 30 year old boat that only ever had v8's in it so assuming that all good where else should I look? Is there a manual that covers this area of service? I have manual 31 currently but didnt see anything there.
Ayuh,...... Boat tachs live a tough life, exposed to weather, 'n splash, so are notoriously inaccurate,.....
Sometimes, just rotating that selector switch back, 'n forth a few times will bring 'em back to reasonable accuracy,..
Sometimes not,..... then you replace 'em,....
For truly accurate reading, I use my timing light, that has that function,...
woodguy81
No other ideas? Ill look into the gauges themselves but where do they read from on the motor side?
Ayuh,... The tach gets it's signal from the (-) post of the coil,....
