bravo one drive shaft.
steelerone
installed new bearings per the manual but I can't get any resistance after tightening the nut all the way I double checked and everything is put back correctly
alldodge
I also have a beam inch pound torque wrench and neither one shows any resistance
I'm not able to help if I'm not able to see what your seeing.
A beam wrench is good but if there is no means of actually seeing "max" torque than it's useless
Same goes for dial wrench
Need to be able to set a marker on the wrench and then rotate wrench. The marker will move based on amount of torque encountered.
Jesse Walter
I just installed and set the resistance for mine today. I wasnt getting any resistance at first either. Just had to tighten the nut a little more. Then worked my way up very slightly checking each time.
