0_KRAK3N_0
- Jun 20, 2025
- 5
Good day all,
So, removed the lower unit to replace lower shift cable, while it was off I split the lower unit for some skeg repairs, I can't get the drive spline to line up, due to the vertical drive shaft on the lower not budging. Prop shaft will spin, can shift into fwd,neutral,rev, and the prop will catch the clutch for all gears, but will not move that drive shaft at all maybe 1/8th inch. The boat ran prior to the repair.
